engine problem!!!!!!!!
hi,i have a savage ss and just finished break in and started tuning and noticed a problem! at hight speed passes and after the second speed i hear a noice like the truck wants to change another gear! as i lean the mixture the noice comes closer to the changing of the gear ang when i rich the mixture it makes the noice later! some times it doesn't do it !
what do you think the problem is ?
what should i do?
what should i do?
RE: engine problem!!!!!!!!
it sounds like this :iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii"s econd gear"IIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIII IIIIIiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii IIIIIIIIIIIIIiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii and i think i saw the front of the truck going a bit down as it does this sound str.sound
at the begining i thought that something was wrong with the asphalt that i was breaking in like a stone or a hole in it.
at dirt no problem everything works super!
ORIGINAL: grecospad
also on my revo the front right wheel is jumping at high speed,do you have any clues about it?
That sounds like a mistuned LSN. The engine is hesitating when the HSN is about to take over completely. Try to richen your LSN about 1/8 of a turn. That should do it for you.[8D]
