Pilot for 35% extra
OH
Pilot for 35% extra
Looking for a kick ***** pilot for my 35% extra......want it to be foam or something other than thise composite ones...
thanks!
-Phil
thanks!
-Phil
My Feedback: (39)
RE: Pilot for 35% extra
The "Little Dave" from Troy Built Models is a realisitic looking pilot and it's light.
http://www.troybuiltmodels.com/Pilots.htm
I have one with the red shirt in my 2.6m Extra and he looks great. I've never seen another one, so you won't have the same pilot figure as everyone else!! It's a little hard to see the detail in this picture, but you get the idea.
Later,
Dean
Later,
Dean
OH
thanks a ton...but i have a question.....why is it so much? its not a composite, and its almost 70$. is that a lot or am i just over reacting....
once again thanks!!
-Phil
once again thanks!!
-Phil
My Feedback: (39)
It's close to the others. Most stock pre-painted pilot figures are $50 to $60.
The "Little Dave" is made by the people at Crazypilots.com that make the custom pilots from your photos. I'll give you their quote on the construction. The figure is "cast in light plastic resin then filled with foam for strength". It comes taller than what you need. You can customize the height to your cockpit. It was easy to trim it down to the right size with a dremel drum sander. Then you just take the whole figure and lightly sand it on top of a sheet of 320 sandpaper to get it perfectly flat. It installed quickly and it's light.
Let me know if you're interested and want a better picture.
Later,
Dean Bird
Sun Valley Fliers
Phoenix, AZ
Later,
Dean Bird
Sun Valley Fliers
Phoenix, AZ
