Best/lightest weight fuel proofing?
Looking at the inside of a DF plane and 1/64th ply duct tube and seeing all the balsa, bulkheads, etc., I'm wondering what's the best-and easiest way- to fuel proof the 'guts' without adding several pounds? I've used spray polyurathane, alcohol/epoxy, and plain ole spray enamel on firewalls, but seems like a lot of weight for a couple of sq. ft. What do you guys use?
SC
I generally use thinned epoxy or finishing resin, but if I'm after the lightest solution, I use dope. Use at least 2 coats, but much of the fluid is solvent which evaporates, leaving a lighter fuelproofing solution.
