Which adapter cable for newer airtronics radio.
Hello:
I just bought the Real Flight Deluxe and would like to use my Airtronics radio. What do I need to hook up to my computer to play the sim? It's a 4 channel vangaurd series. Also, where can I buy it?
There is a special cable thats used for the Futaba 9C and Airtronics radios.
I don't have the info in front of me, but, if you'll call Tower Hobbies, they will be able to give you the info and supply the cable.
http://www2.towerhobbies.com/cgi-bin...1&I=LXNW27&P=V
AIRTRONICS: **for most Air TXs, You Must Also Purchase Adapter Cord GPMZ4062**
(except: Infinity, Stylus or Quasar)
This is the RealFlight Airtronics Transmitter Adapter Cord For Use With
The RealFlight Interface Systems.
Great Planes Software Support Phone Number: (217) 398-8970 Option #1
FEATURES: Allows The Use Of MOST (see comments) Airtronics 4-10 Channel FM or
FM-Compatible Transmitters With The RealFlight Interface System.
Delivers Up To 8 Proportional Control Channels.
(Others Only Offer Four)
No New Controller To Buy, And No New Control Layout To Learn.
Modelers Use The Same Radio That They Use On The Flight Line or
Heli Pad, Getting The Exact Same Results Including Changes To The
Mixing Programs On Computer Radios. This Enable Modelers To Test
New Set-Ups Before Trying Them Out At The Field.
INCLUDES: One Airtronics Transmitter Interface Adapter Cord.
(This Will Plug Into The RealFlight Interface.)
COMMENTS: The RealFlight Interface Can Be Used Only With Great Planes
RealFlight Software. Not For Use With Any Other Software Programs.
JAL 6/24/99
This cord will not work with the Airtronics Stylus transmitters as
these advanced radios do not use the same trainer chord as most
Airtronics radios. RDT 10/15/99
ir/jl
JAL 6/24/99
ir/jl
