Picture Hanger Wire
Picture Hanger Wire
Has anyone used Picture Hanger wire for their flying wires? I have been told that fishing led was a good choice. While at my local hardware store buying bolts, I noticed some thin picture hanger wire that looks like steal cables. This looks like a cheaper, but stronger alternative to buying kits from the local hobby shop. I am not worried about the added weight since that plane has a heavy gas engine on the front.
Lee
Lee
OH
RE: Picture Hanger Wire
For asthetic purposes it's OK, but not for functional flying/landing wires. It is not strong enough.
You can do what you want, but I'd hate to see someone center punch the ground with an airplane over $1.69 roll of picture wire.
[sm=drowning.gif]
[sm=drowning.gif]
This has become an interesting thread. If picture hanging wire can suspend a 40 pound picture and goes on a plane that is very docile would it be safe. That is the big question. There are different thoughts being voiced. I am leaning toward leader wire for fishing since that has been suggested by a few people I know who are extremely good builders. But, if the hanger wire is steel and tested for a 40 pounds, why wouldn't it work? Again, just curious not looking for flame on situations. Looking to build that's all
Picture hanging wire is steel and will be just fine. Fishing leader is however better quality steel and most will be stainless steel. For the same diameter wire the fishing leader will carry a greater load. Fishing leader packaging will tell you more about the loads that can be carried and it is designed to be flexible.
Bill
Bill
Thanks Bill,
I stopped by my field today on my way home from work and spoke to two guys that I respect their building knowledge. Both said go with the fishing leader wire. One had one of his "Little Planes" with him, a 40% Radiocraft that he had used Fishing leader for the pull/pull rudder setup. Stuff looks great and I have seen this plane fly so I know it can take the little stress that my 1/4 scale Cub and my 1/3 scale Spacewalker can dish out. So I will be going with the fishing leader.
Thanks for everyones input.
IL
DR. Take a pair of side cutters and cut some picture hanger wire and you will find that it is really soft. I would also recommend the fishing leader.
Al
Al
FWIW, the common misconception is that stainless steel is stronger than carbon steel.... NOT true.... and, since it has so little carbon, stainless steel can not be heat treated to be anywhere near as hard as carbon steel..... that's why stainless makes such lousy knife blades...
My Feedback: (10)
Not to enter a metalurgy debate but... strength and toughness are two different qualities. Sugical blades are made from a version of stainless (400 series) that has carbon in it to give it more toughness and hardness, yes it can be hardend, it is magnetic, and will even rust under the right conditions[X(]. The leader material is made from this type of stainless steel.[sm=thumbup.gif]
