jato with?
IL
RE: jato with?
With an O.S. TZ the JAto would flying. That engine has some serious power behind it. You might burn a diff but if it worked you would be damn fast. You would be doing 60+mph.
IL
RE: jato with?
Yes I am pretty sure It does. The mounting holes on the Traxxas 2.5 engine are almost identical to those of the TZ. It would be able to fit but the crankshat would be different.
IL
RE: jato with?
No the engine fits perfectly. It is only off maybe .03 of an inch and that is really no difference. It will fit. If it doesnt you would barely have to trim it. I say if you wan it, it will fit.
