CA Model 31% Extra tail support
Old 06-19-2005, 08:53 PM
Chris Moon
My Feedback: (8)
Chris Moon's Avatar
Default CA Model 31% Extra tail support
I am building a CA Model (Colombo Anderson) 31% Extra and the instructions call for tail support wires. I have seen pics of several of these at 31% and 34% and can't see any tail wires. Are people using these wires or leaving them off? I don't mind putting them on if they are necessary. Thanks!
PS....the kit is excellent, but the instructions leave a lot to be desired
Old 06-19-2005, 09:06 PM
matus777
Default RE: CA Model 31% Extra tail support
Lotto....those are built up surfaces as opposed to flat surfaces? If you decide to use flying wires let me know as i have some already made up that you might be able to use?
Old 06-19-2005, 11:13 PM
Ryans Rebel
My Feedback: (12)
I have the 34% and do not use flying wires. I have over 200 flights with 0 problems.
Ryan
Old 06-20-2005, 10:12 AM
Chris Moon
My Feedback: (8)
Chris Moon's Avatar
Thanks Ryan. I might just install the hard points and monokote over them. That way I can add the wires later if I change my mind. I just don't remember ever seeing one w/ the flying wires attached.
Old 06-20-2005, 10:19 AM
famousdave
My Feedback: (61)
We have had many of these planes, none had wires and none have had any problems. If you are planning on doing nothing but violent 3D, put the wires in and DEFINITELY replace the Anti Rotation (A/R) pins with Carbon Fiber, the crappy wood ones in the kt WILL FAIL.
If you are only flying IMAC with some occasional 3D like hovers, harriers, rollers, etc - the wireless / stock A/R pin design is fine.
If however you have not installed the A/R pins yet, by all means - get some Carbon Fiber or Arrow Shaft (Fiberglass) and do it right!!
DP
Old 06-20-2005, 11:12 AM
Chris Moon
My Feedback: (8)
Chris Moon's Avatar
Thanks guys!
I didn't think the a/r pins would be anywhere near sturdy enough so I replaced the dowels w/ 1/4 brass tube and epoxied the dowels inside the tube. I have used this setup before, and it has held up very well, although I like the c/f idea too. I am just going to delete the tail wires for now but put in the hard points for later...Thanks again
Old 06-25-2005, 12:45 AM
furloughed ual
My Feedback: (31)
furloughed ual's Avatar
here's my 31% CA.....no wires and no worries.....wasn't babied either....[:@][:@][:@]
ID:	289447   Click image for larger version
ID:	289448   Click image for larger version
Old 06-25-2005, 05:14 AM
Chris Moon
My Feedback: (8)
Chris Moon's Avatar
Thanks Furloughed your plane looks great, can't wait to finish mine now....Did you get recalled yet? I came back Nov 1st and it is having a very negative impact on my r/c playtime.
Old 06-25-2005, 07:55 PM
furloughed ual
My Feedback: (31)
20 from the BOTTOM.....[]
Old 07-11-2005, 08:47 PM
BigBirdFlyer
My Feedback: (13)
BigBirdFlyer's Avatar
Nice looking Extra. I just ordered a 31% CA Extra. Are there any building tips I should know about. I'll be using a ZDZ 80.
Old 07-14-2005, 09:25 PM
furloughed ual
My Feedback: (31)
nope.....built mine stock with no additional bracing (less in some places I believe)....it's a good design.....
Old 07-15-2005, 05:31 PM
BigBirdFlyer
My Feedback: (13)
[8D] Did you use pull-pull on the rudder or are the servos in the rear? Did you install smoke and if so where did you put it?. I noticed your landing gear is black. Is it carbon fiber? If so where did you get it? One last question. Did you have to add weight to balance it out?
I hope this isn't to many questions. I just want to do it right. Thanks [sm=drowning.gif]
Old 07-15-2005, 11:16 PM
furloughed ual
My Feedback: (31)
pull- pull on the rudder with the servo in the rear of the tray.....graphtec gear (about 1.5" taller....with 24" prop on standard gear, 1" prop clearance.....no problem if you 3 point it every time and take off tail low)....no smoke.......no weight added....balance acheived with batteries......
Old 07-15-2005, 11:17 PM
furloughed ual
My Feedback: (31)
oh yeah, power at 5400' is awesome....in WA it'll be ballistic on the up lines.....[:-][:-][:-]
Old 07-16-2005, 02:37 PM
BigBirdFlyer
My Feedback: (13)
You said 24" prop ? What size are you using. I've always used a 26 X 10.
Old 07-16-2005, 10:10 PM
furloughed ual
My Feedback: (31)
26X10 is no good at 5400'.....24X10 is the ticket in the mile high city for 3D type flying.....
Old 07-17-2005, 01:36 AM
BigBirdFlyer
My Feedback: (13)
Thanks for you're help......
