READ K4.6 owners and engine guru's
i am fed u p with my wasp. finally retiring the engine. now, i want a engine that hold it's tune and is easy to start. i want a fast motor. no .30's or huge motors that will shred my drivetrain. my bro is buying this and he drives it alot and dosent want a mach or xtm .26. i want a motor that will start up every time. please someone post sonme info or vids of their motors. i'm taking the k4.6 into consideration. putting stock motor for now, hopefully you guys will anser quick cuz i dont want to drive the s-25 for too long.
how's the pullstart and tunabilty on the k4.6
RE: READ K4.6 owners and engine guru's
I have a basically stock 4.6 ( with the k4.6 engine ) and it has been very strong so far. I only need to make minor adjustments to the hsn when i take it out, to deal with daily temp fluctuations. I have put 13 litres (we are metric in Oz) thru so far. It runs well and does not overheat. I have broken 2 pullstarts however. I think the spring has a hard time dealing with the compression. I just put a roto start backplate on and found that my drill is fast enough to start it from cold. I'm still unsure that i like this but i will give it a go.
Hope this helps
Hope this helps
My first pullstart came off but after putting some lock tite on the pullstart screws it has been fine. I do not like my 4.6.
ORIGINAL: mosavage
You want "fast" get the Sportwerks .26, a screamer of an engine.
You want excellent overall power, with almost idiot proof easy tuning, get the XTM 24.7 Pro.
I don't have any problems with my 4.6. I tried the WASP .28, but it was too hard too keep tuned so I put it up on Ebay. My 4.6 SS runs strong and pulls away from the .28 WASP. I hardly ever have to adjust the tuning to keep it running, just get fuel to the engine and it starts right up.
i wanto go up or stay at the performance level of the wasp. i was looking around and also saw the picco .27. an1 have one of those.
I have the K4.6 and I can't be more happy , I can't remember when was the last time I tuned the engine.
Mine is geared 19/47 and with the 3 speed gearbox and Dirt Bonz it's crazy fast.
