hacker motors
GA
RE: hacker motors
You could use the mount that came with your motor or if it didn't just fabricate one... and then glue it to the front of the foamy.....
I had to do it on one of mine.... I used the stick mount as a guide as to where the thrust line should be...then cut away and then glued the hacker motor mount on....
works the charm
works the charm
