Run times with RB323 engine?
RE: Run times with RB323 engine?
OK thanks Revofamily[sm=thumbup.gif] Does anyone have a reliable power output figure for the TRX 2.5?
just got mine brocken inan it is loud as H-E-L-L icopter when you guys find I pipe that doesnt't constrict the power e-mail me please.
revofamily can you tell when you shift into second is there a sound change I have the same set up as you have I'm just to the point where I'm going to start to lean it out but dont want to chnce it till I get my temp gun this weekend already been having a little trouble check my thread JUST OT MY RB FOR MY REVO
HOLLA BACK!!!!!
HOLLA BACK!!!!!
#31
AZ
I can hear when it shifts to second... beware that it may be shifting early, which you may not hear. With the RB, the engine is so powerful... that it will still accelerate at a high-rate of speed when in second gear.
#32
I have just finished running in my new RB .23 and it stripped my output gears... i have a robinson racing forward and reverse gears any they are holding up well but the final gear in the drivetrain has stripped right down already.
is there a metal version available? cos i cant see one anywhere
and yes, my new RB .23 is loud... very loud, so if anybody has a fix that does not cut the power down then that would be great!
thanks in advance, Alex
#33
Thanks. compared to the trx its like comparing a corvette to a cavalier. And I learned a new word that everyone should learn with this engine THROTTLE CONTROL!
So I should start with the shift point like a quarter turn from all the way closed
#37
i have gone from a 16t clutch bell and a 72t spur to a 22t bell and 70t spur
and i just did a backflip changeing up into second!
