Seagull Decathalon 40
OK
Does anyone know where I can find a manual online for this plane? I bought it second hand. If not, what is the CG and the control suface throws?
RE: Seagull Decathalon 40
Twistr
You need to go to the ( Search ) Seagull Decathlon thread. Now.....read alot of that thread BEFORE you try to fly this plane. Not to scare you ,but, there are issues you need to know if you want to fly this bird more than once.
Been There Done IT
Bill
Been There Done IT
Bill
Twistr
Ok , Im back. Here is what the manual states:
The center or gravity is located 8-9 cm back from the leading edge of the wing, measured at the wing tip.
Initial flying low rate:
ailerons 3/8 up 3/8 down
elevators 3/16 up 3/16 down
rudder 3/4 left and right
Bill
Bill
