help gear ?
Old 02-02-2006, 09:44 PM
68l89
Default help gear ?
im looking for a gear that will fit this shaft Diameter: 3/16" + .010" [or 0.197"] (5.0 mm)
Exposed Shaft Length: 1/2"
i usually use the 3949 with a 550 series motor...i switched to a 700 series motor but still need to use the 19 tooth 32 pitch gear.
is there a gear with a bigger diameter set screw hole but still uses the same 19tooth configuration as the 3949??
thanks for your help
