fuel flow problem!
fuel flow problem!
I can't get my savage .25 to start. There doesn't seem to be any fuel flow through the line. It's not leaking... I checked that. What else could be the problem?
NY
RE: fuel flow problem!
some thing happened to me like this there was no leaks and when i would try to prime it the fuel wouldn't go. i took off the high speed neddle and then tried to prime it again and fuel went through it and it worked but i also put it back to factory settings.
nick
nick
Fill yout tank, make sure the lid is sealed by pushing down on it. Then cover the exhaust opening with your finger. Turn over engine and watch the fuel line. When fuel reachs the carb , stop cranking. Now it should be ready to start. Put glow plug igniter on and try cranking engine over. Hope this helps..
