new CAmodel extra 330L??
what do you guys think about the new extra 330L from CAmodel? I'm about to maiden my WH edge and would love to build a kit and have another plane for the DA50. i was thinking about the CA 27% extra 300 until i saw the new extra 330
how do think the extra would compare against the WH edge?
RE: new CAmodel extra 330L??
there is not to much info but you can see the plane on there website http://www.camodel.com.ar/
it comes in 26% - 30% - 33% - 38%
Aeroworks has them in stock. I just ordered the 30% 330L new kit, so we'll see when it gets here how it is. They have a manual online now - at least part of the manual.
Changes I noticed and Rocco at Aeroworks pointed out between the old kit was this one has more interlocking to it, counterbalances on the elevator, and the kits is set up for a normal bevel on the ailerons instead of the old top hinge style (which most people changed to a bevel anyway).
Price went up a fair bit. Old 31% was $425 new 30% was $649 but I got a good deal on it shipped for $600.
Getting hard to find kits now period, let alone one of a plane you actually want. Aeroworks has the edge but I wanted an extra. Plus it's kind of an odd size - I wanted a 75cc size airframe etc... To me the 27% is just a tad too small for the DA-50 tho I know lots of people run those on em I could use a touch more size/wing area. I plan on sticking a 3W80xi on this one so we'll see. Not a fast builder so this may fly next year....
Yeah but Carden only makes 35% and 40% kits now. I wish they would jump on the 30-31% size bandwagon now that there are an abundance of hot motors in that size - ZDZ80 and the 3W80 etc...
Other than CA and AeroWorks I don't know anyone who makes 50cc and 80cc size kits.
Here's the new kits specs.
http://www.camodel.com.ar/Ingles/models1.htm
Also says an edge is coming soon.
Taken from the website.
Differences with the Extra 300L of our own production:
Stab with counterbalance.
Taller fuse.
New wing airfoils.
New building system, more simple, stronger and lighter.
Less maintenance with anti-twist system.
New engine cowl.
Plug-in stab in all version and scales.
100% Laser cut.
In kit, ARC and ARF versions.
Preformed "V" sticks for hinghing.
Wing tips, stab tips and rudder laser cut in balsa.
Taller fuse.
New wing airfoils.
New engine cowl.
100% Laser cut.
Started a build thread here.
http://www.rcuniverse.com/forum/m_39...tm.htm#3949906
be warned it's gonna be slow going at first.
