savage 3 speed
BC, CANADA
RE: savage 3 speed
this will be painfull! disassemble the tranny, im sure you already know how to adjust the 1st gear. so find that screw on the second gear and adjust it as if you're normally adjusting the 1st gear. then put it all back together and see if you like the result, of not, repeat the process!!! ima switch back to 2 speed
MI
RE: savage 3 speed
the adjustment screw for second to third is accessible thew the access hole, its first to second that you have to take it apart to change.
turn the bottom grub screw out counter clock in 1/8 turns till you get it where you like. mine is 2.5 turns out from in snug.
