21 and 25??
RE: 21 and 25??
you may need to define your question to get the answer you are looking for.
25;
more HP
More torque
bigger carb
physically no difference apart from the heat sink size and shape. alittle larger.
25;
more HP
More torque
bigger carb
RE: 21 and 25??
thanks for the correction.. I just read the 21 , 25 .. missed the savage 21, 25 .. derrrr I should spend more time reading properly.
some other differences are,
25 had,
revised hardness of diff cups and gearbox cups
brake/throttle servo mech is revised,
25 SS have adjustable upper arms,
the setup for spur gear was changed to 1/2 turn back,
the front and rear top shock screws were shortened,
the standard CB was 15 and optional 18
Rotostart on RTR 25 but not on SS or 21.
Headlight colours on RTR21 were diff to RTR25.
Otherwise they were virtually the same.
25 had,
