GPM BI DIRECTIONAL POWER UP CLUTCH flywheel diameter
Hi there. After trying to get a replacement for my clutch which I THOUGHT was a Fioroni Turbo Sliding, I found out that it is not. My flywheel has 38mm diameter and that's what I want, all the Fioroni versions have 35mm - that's what Mr Fioroni says himself. I made a lot of phone calls and the German main importer and distributer found that out for me.
My clutch is a COPY of the Fioroni, as far as I have found out it is the GPM BI DIRECTIONAL POWER UP CLUTCH:
I don't know the part # of my 38mm flywheel - bought it in the bay - but I think it is SAV1100X08 (found that out on gpmracing .com). The purple SAV1100XH is said to fit into the Hellfire which needs a 35mm flywheel, right?
Noone of the dealers has responded to my emails so far. I can't ring them up because I live of the other side of the world.
Can anyone confirm or falsify my assumption that the silver colored GPM SAV1100XH shown in the picture has a 38mm diameter flywheel? The clutch I use is killer with the Fioroni carbon shoes and I wonder if it gets any better with the 7075 aluminum shoes. Anyway, I need that flywheel IF IT IS 38mm.
Is it? Does anyone know?
Thank you very much, Ferdi
RE: GPM BI DIRECTIONAL POWER UP CLUTCH flywheel diameter
The problem remains...
I HAVE such a flywheel in 38mm abd want a second one because I have to motors... I have no idea where to get one...
ORIGINAL: burnchassis3
Have you measured it??
MM = milimeters...
MM = milimeters...
