Radio with big range
RE: Radio with big range
After reading the stats 100mW output for Sensor 2.4ghz SHOULD be greater then the 10mW range of spektrum 2.4ghz am I wrong in thinking 100mW is going to get you more range then 10mW?
The one with the biggest antenna
Not hardly, sorry, couldn't resist.
Most any decent system................ installed correctly.................... will allow control further than you can comfortably view the model.
Ed M.
Ed M.
ORIGINAL: Watch-out-for-that-frog
