ABX engine on takeoff
I've got a new ABX that i've flown about 5-6 times (without a crash thusfar ) and i've noticed that sometimes on takeoff (on a full battery) that the engine can cut out for just a second. I think it's done this about 3 times and always recovers in time for me to save it (not sure if i've pulled back on the throttle and then forward full again or not as it happened so fast and i was having fun). I've seen two posts in other conversations where peoople have mentioned this happens to them . . . . is this common or should i call HobbyZone?
Kevin
Kevin
RE: ABX engine on takeoff
My firebird freedom has done the same thing a few times. Seemed to only do it when the battery was at a full charge. Mine would actually cut the motor off like it was a low battery.
I would just run it for about ten to thirty seconds and it would go away.
The plane is in a tree so I dont know if the problem ever went away.
I know this thread is about 6 months old, but I have found that a upgraded ultra dean plug seems to solve the motor cut-off problem. The battery plug came with ABX and Firebird is not really mean for repeated use.
ASM
ASM
