Rascal 110
RE: Rascal 110
Does anyone know the demensions of the vertical and horizontal stabilizer on the RASCAL 110. I am trying to find out if it will fit in my Volkswagen Bug. I can get my KADET SENIOR ok.
My Feedback: (91)
RE: Rascal 110
I just measured mine "VerticleStab" Ground to top of Verticle Stab=20 1/8th" tall Horizontal Stab=36 1/2" wide I hope your able to get it in your car it's a great flying plane, and looks good in the air. Remember.........If you really want the plane, get it. You'll find a way to get it to the field.
RE: Rascal 110
I am supposed to pick up the Rascal 110 kit Friday and will begin putting it together soon thereafter. Anyone have any suggestions on things to look for before I start. I have a Kadet Senior that I am presently flying and I love it. I didn't have any problems constructing it.
This is my 2nd kit (ARF) after being away from the hobby for thirty years.
Will be thankful for any replies.
My Feedback: (42)
OH
RE: Rascal 110
Great airplane to fly,my 110 has had the firewall come loose and last night the stab broke 3 out of 4 flying wires, pulling the complete tail feather assy 75% from the fuse. So my 2 cents says its worth everything you have to do to strengten the plane because its worth it. The fire wall was pretty easy, I added ply stringers extending back into fuse and covered all on the inside with fiberglass cloth and resin. A little weight but certainly not a hinderance. It carries my super tigre 3000 quite well, and have had no signs of added stress after lots of flights. Someone mentioned earlier in a 110 thread about flying it within the limits of its construction, I thought mine would be different, THEY DO HAVE LIMITATIONS. While the planes capabilities are endless they just dont hold up well on 3D. I have had no wing problems yet, just the two areas mentioned. Good luck assembling and happy flying !
My Feedback: (7)
RE: Rascal 110
ORIGINAL: brutonj
Here are some links to my build notes and picts in case anything there is helpful ...
http://www.flightgear.org/~curt/Mode.../Construction/
The re-assembly is always a little more tricky and involved ... :-)
http://www.flightgear.org/~curt/Mode...110_1/Rebuild/
Curt.
My Feedback: (8)
SD
RE: Rascal 110
I just flew my Sig Rascal 110 for the first time last night, it is equipped with a Sato 150, what a delight to fly. Not only does it fly great with fuel, but was able to fly for a long time when the fuel ran out. To date this is by far the best flying plane I have flown.
My Feedback: (7)
RE: Rascal 110
ORIGINAL: vdraper
