Yellow F-16
Yellow F-16
Hello im new in this site and i have a question
for some weeks it has been buying a Yellow F-16 i I think to make it DF it wanted to know if this airplane flies well in DF?
RE: Yellow F-16
Which F-16 is it? They made two version at one time one scale and the other sport . Both flew okay in fan but the sport was a lighter airplane. Also make sure you put in the extra openings for the inlet greatly reduces take off roll and good luck.
My Feedback: (57)
RE: Yellow F-16
Im working on one right now, which I've flown a couple of times. Mine has a Ramtec/OS .91/Weston pipe. It flies great but it takes a looooot of runway.
Keep it light and use the cockpit for static display only, remove it before flight. Keep that ******* as light as possible and you will have a blast!
it looks really good in the air.
David
David
RE: Yellow F-16
How about the turbine?I will install the ArtesJet super Bee in my new yellow F-16.I will weight
about 16 to 17 lb.I am worry the landing speed.Dose anyone have the valuable experience,thanks!
NJ
RE: Yellow F-16
I hope to have mine in the air tomorrow.It has flown on the fan and os 91.Now it has a Ram 500 in it.I have working out all the bugs this week. Now it is ready to go cant wait! It came out at 15 lbs dry, and holds 54 ozs of fuel.I tried to take off on a grass runway today it would not rotate.
My Feedback: (57)
RE: Yellow F-16
ORIGINAL: ledd4u
Ok, old design, hard to see, takes forever to get up, old technology, oily mess, glow plugs, wand, slow, noisy, vibration, 1 to 4 ratio, 1 flight 4 repairs.....etc. Just my 2 cents worth.
P.S Yellow sucks anyway.
1. Not sure why you would complain about Yellow. I've seen most F-16 kits, Yellow is deffinetely up there. You must have not seen the Epoxy-carbon version. Makes any Tams, Cermark, Skymaster, and even BVM look like toys. The only other F-16 I've seen that is also really good is the Avonds, probably the only other one I would buy/fly.
2. If you are complaining about DF's, just get a turbine and all of your problems will go away, like it happened with 75% of DF pilots. That's why many will not ever get passed the twin-boom stage. Typically most of the "good" turbine pilots I've met were even better at DF and mastered the "old technology". I see them locally tearing up the sky with F-4's, Bandits, yes and even Bobcats.
I woulnd't discourage anyone from trying Ducted Fan. It is cheap and contrary to what most pilots think, it is reliable. Sorry for all you former Rossi, Pico, and K&B owners. But we did learn from your mistakes.
David
My Feedback: (48)
RE: Yellow F-16
Ledd4u said:
"Ok, old design, hard to see, takes forever to get up, old technology, oily mess, glow plugs, wand, slow, noisy, vibration, 1 to 4 ratio, 1 flight 4 repairs.....etc. Just my 2 cents worth.
P.S Yellow sucks anyway."
There is nothing wrong with the Yellow F-16. It's a great flying jet. Sure there are a lot of advantages to turbines, I also fly them. My DF F-16 has 296 flights on it. If you know what you are doing you can be sucessfull with DF.
Joe
Joe
My Feedback: (57)
RE: Yellow F-16
ORIGINAL: ledd4u
David I am not complaining about anything I have a turbine powered jet. Your # 1 statement is actually backwards I will edit it for you so the facts are stated correctly.
1. I see why you would complain about Yellow. I've seen most F-16 kits, Tams, Cermark, Skymaster, and even BVM are above standards when comparing them to Yellow. You must have not seen the quality and size. Makes Yellow look like a toy. The only other F-16 I've seen that is also really good is the Combat models F-16 which is probably the only other one I would buy/fly other than Yellow.
Thats the way it sould have been written.
See you at Top Gun.
NJ
RE: Yellow F-16
Just returned from the airport.I put two flights on it today.WOW! It flew so stable no bad habits.Both flights 4 mins.It used 32 of 54 ozs.Most of the flying was done at 1/2 throttle.Top speed was sweeeet.Vertical just as good.I cant wait for this weekend,Capital jets.
