3/4" hole in Balsa? How?!
My Feedback: (14)
I need to drill some 3/4" holes in the elevator and rudder to put some dowels in as reinforcement for the control horns. Besides the old sharpened brass tube method, any good ideas.. I'm wondering if a Forstner bit will work. Just want to know if anyone else has had luck with them, they're $$$ for just drilling 3 holes.
thanks!
thanks!
RE: 3/4" hole in Balsa? How?!
Draw the circle by whatever method you use - circle template, compass, etc. Use your #11 blade to cut close to the scribed line. Now use a drum sander on a Dremel tool, or a piece of sandpaper wrapped around a smaller dowel, say a 5/8", to enlarge the hole to the proper dimension.. This method will give you a very accurate hole to hand fit your dowels into. Remember, dowels are often not accurately made. Even a Forstner bit is too dull and will probably tear the soft balsa.
Dr.1
Dr.1
I have tried a Forstner bit. Even though my set is very sharp it shredded the balsa beyond recognition.
You can buy 3/4" hole saws. That might work.
I have used large diameter end mills with four or more flutes. Chuck them up into a drill press, run as high RPM (2000+) as possible before tounching down to cut a hole. Sharp ones can be found at swap meets around here for about $2 each. Most often they are very accurate as to diameter, unless they have had their sides sharpened along the way. Other problem may be in that for a tight fit, your wooden dowels may not be all that accurate of a diameter.
Wm.
Wm.
Mcmike, what kit are you building? Myself was look for an answer to the same question. Thanks for clearing the ground for me. I need 1/2" holes for the very same reason on my Lanier kit.
