How to install a hay's whip antenna?
My Feedback: (7)
It says receivers with 18'' of antenna wire and less to cut and leave 1 inch of antenna wire coming out of my receiver. I am supposed to cut the receiver wire? And I need to solder the othere wire to it.
Thanks!
Thanks!
RE: How to install a hay's whip antenna?
which hayes whip antenna are you using?.....the base loaded hayes whip works well on the jets....i've never had any problems using the hayes whip.......
richard
richard
i made a mistake in commenting about the hayes whips.....i've never used a hayes whip......i only use the deans whip with great results on my jets.....
richard
richard
