Kind of nervous to fly MAIDEN
RE: Nervous to fly MAIDEN!!
Get everything set up...do a run up and taxi test...then afterwards taxi back, shut down and go for a walk along the runway / field. Fuel up and GO!
D.W.
D.W.
My Feedback: (10)
Make sure you have failsafe shutdown enabled, and that your spotter knows how to shut the turbine down if you loose it. Easy to start a fire with full tanks and a turbine screaming in.
Remember to throttle back after it gets going, many people forget to throttle back and that stingray can get away from you.
Make sure your caller can handle your trims for you and that you guys have a lot of experience flying together, that helps if he can help keep you calm.
Make sure you are not nose heavy or you could have a very hard time landing it. Also watch the elevator trim with the speedbrake up, it can be severe if you are nose heavy.
It will tuck in the turns (like a lot of deltas do) so if you are not used to it, be ready with plenty of power and elevator pressure to get around that turn. Stay up high till you are through a few circuits. But keep turning! If you hesitate that plane can get away from you.
I have maybe 110 flights on mine.
Good luck,
Good luck,
Mario,
Are you sure you are ready to fly this Stingray? Only 5 months ago you were asking questions on setting up a 46 powered trainer. The stingray is not a beginner turbine. You do know you MUST have a turbine waiver to fly at any AMA field.
John
John
My Feedback: (7)
I will be flying at my friends ranch in Marysvale. We made a 550 x 45 foot runway on thin grass. And yes I think I am ready to fly the stingray. I trust myself. I can say that usually everything I do the first time I get it. Just one of those guys. I had a brushless stryker clocked at 136mph!! ( I know TOTALLY different than turbines)And since my .46 gas trainer I have had the Matt chapman 580 and the lanier Extra 330 and flew those wonderful. I really dont want to spend another $600-$900 on the boomerang. Whats done is done on the Stingray. Thanks guys for all the imput. I'll you let you guys know how it goes! :-)
It would be a good thing if you are that nervous to get someone else that you trust to take it up for you and to stand with you for the first few or so flights.
The Stingray Fly great is easy to takeoff and fly, for landing first time try to have at least 200 meters but is not difficult to do, just make a good approach. practice, practice, spend your fly time doing approach, feel the plane with landing gear down and full Speed brake and that it. Not difficult to land just a little fast
http://www.youtube.com/watch?v=Fdo8XV5AcxE
Hi,
Don't realy think the stinger is a beginners model but once you get used to it you'll love it mine goes like stink.
Relax take off easy don't let it build up too much speed on the first few flights on landing do a gear pass with 40% power the go all the way around again keeping that power then once you come over the strip again airbrake up which will slow it again - nice long low approach and touch down easy.
Enjoy
Ant
Enjoy
Ant
experienced jet guy as a caller you will have a greater chance of success.
Good luck with it, Enrique
My Feedback: (57)
Some serious recommendations.
I also thought I was "one fo those guys" that can fly anything, until I broke a set of flexplates. No big deal but I was very amazed on how different it is to fly a turbine model.
Dude, they geat away really quick.
136mph is not that big of a deal. That's normal cruise speed on most models. The big deal is the high wing loading. When you turn the nose will want to fall, more noticeably than on prop planes.
Another thing to think about, you must bleed off airspeed to land. You almost have to "stall" just an inch or two from the ground. If you don't then the model can bounce and it is not the same bouncing as a prop model. This time it will hurt the airframe. So concentrate really hard on greasing it in for landing.
If you think you are too high on approach, just go around. Go full power for this, don't be afraid as turbines do not hick up like glow engines. And be very carful about going to full idle.
Once you go to idle it will take time to recover, plan on it. I typically go to idle once I know I have enough altitude to get to the runway safely, typically when I'm over the threshold.
Good luck, I wish you well. It can be done. You will most likely beat it down some but that's normal.
If you feel nervous, enjoy it, that's the whole point. Have someone help you out and preferably fly it so you can see how it handles. "Cojones" are not shown because you maiden it by yourself for the first time, believe me it doesn't impress much. "Cojones" are shown when you live to fly another day.
Cheers,
David
Cheers,
David
My Feedback: (16)
Moe,
I get nervous every time I maiden any plane (you never know what could happen), that being said when I first started flying jets I let a friend of mine maiden my first jet. He had experience with jets and I had not flown one. He then told me how he thought it flew and what I should watch for when I flew it.
The one thing you need to think about is if you are nervous is: Is it worth losing you jet and possibly causing damage to people or property if you get into trouble. There is nothing wrong with asking for help.
Good Luck
David
Good Luck
David
1 Post
I have been flying RC for 40 + years and recently graduated to jets via a Baby Boomerang.
Delta disorientation, turbine spool times, speed and a short flight time are all new and real problems to deal with.
Swallow the pride and find an experienced jet jock to buddy box you through the first couple of flights . It will make your first flights more enjoyable and dramatically increase the likely hood of taking home an intact model.
ORIGINAL: j.duncker
Ant
