winter break in
Banned
WA
RE: winter break in
You need to keep your fuel and engine warm, wrap aluminum foil around the cooling tower and stick a heat packet in the top of it, then stick a few around the engine and a few around the fuel tank.
[link=http://www.adorama.com/PBPHP1.html?sid=11594200423499016]Air Activated Chemical Hand & Equipment Warmers, Pack of Two.[/link] I think these would be appropriate, they are designed for keeping photography equipment warm when people climb mountains to take pictures, the packets reach 130 deg. F and last 6 hours. Your engine will think it's in Hawaii. 130 degrees sounds like overkill but since it is cold out a lot of the heat will dissipate.
You might want to put a little plastic wrap around the receiver to keep it dry in the snow (if it's snowing).
My Feedback: (23)
WI
RE: winter break in
Or you can wrap a small towel aroung your engine cooling head then put aluminum foil wrap around it. also keep the fuel lines worm if any way possible just wrap the fual lines with that heat hand warmer stuff so that they wont crack and do the same with the tank.
Banned
WA
RE: winter break in
ORIGINAL: Takedown
It is most important to keep the fuel warm so it doesn't gel up.
RE: winter break in
My opinion is that you should do your static break in indoors.If you have a garage or something slightly open a small window for ventilation,turn on the heating system so you wont freeze and finally start the break in.After you run 2-3 tanks static (the wheels dont touch the ground and the engine runs at idle till the tank empties then repeat process) you'll have to to the running break in. Then you can use what the boys have mentioned...rub the silicone tubes with preheated (in the oven at 40 degrees or with a hairdryer) aluminium paper. Start the engine indoors till it gets hot (hairdryer would also help) and while running outdours increase the idle a little bit so the engine keeps a higher temperature. I hope you'll not have any problems though.
