HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
What Carbs will fit on the Star 25 Engine?
Old 10-31-2006, 11:54 PM
Nitro Ray
Nitro Ray's Avatar
Default What Carbs will fit on the Star 25 Engine?
Please help
What other carbs will fit the Nitro Star .25 Engine?
My carb is loose on my .25 Nitro Star Engine in my Savage 25.
I am having a hard time finding a carb for it for what I want to pay. Plus on e-bay there is not many choices I can find. I Hear some problems with the original carb.
HPI Said I would need to replace the carb. The Engine seems to run ok, but am worried about it sliding back and forth, plus it causes my throttle to be inconsistant.
Thank you for your help, greatly appriciated.
Old 11-01-2006, 12:36 AM
bam.bam
Default RE: What Carbs will fit on the Star 25 Engine?
XTM 24.7 carbs will fit nice. Plus it's a all alloy body. No plastic body to crack which is probably causing your issue.
Look like this:
Good Luck!
Old 11-01-2006, 01:55 AM
bennyblanco
bennyblanco's Avatar
the sportwork carb will fit to!
Old 11-01-2006, 04:54 AM
boydie1
Force .26, SH.28 (not pro-spec). The SH carb also has a larger throat which gave my old S25 a bit more power. It also looks similar to the XTM carb pictured above
Old 11-01-2006, 12:19 PM
fxrs
fxrs's Avatar
For starters, when my carb came lose on my LE I called HPI
and told them about it. They sent me a new carb.
I also have bought spares off of E-Bay. Here are a few
of the ones I have bought and do fit. The losi carbs have a
smaller I.D. but I ream them open to 8.2 mm anyway.
http://cgi.ebay.com/Losi-LST-2-LST2-...QQcmdZViewItem
http://cgi.ebay.com/NEW-OFNA-FORCE-2...QQcmdZViewItem
Old 11-01-2006, 02:39 PM
benzzyo5
benzzyo5's Avatar
this hapened to me and i got a sportwerks .26 carb. but now i got a new engine. it only has 3/4 of a gallon it. if u would like to purchase it pm. but it's pending right now
Old 11-01-2006, 05:23 PM
DaveG55
DaveG55's Avatar
Any carb from a big block engine will fit.
I used one from a Mach .26. The Sportwerks carb is better though because it comes with interchangable inserts. Both are about 1/2 the price of the stock HPI carb. And easier to find too.
Old 11-01-2006, 06:25 PM
fxrs
fxrs's Avatar
Not every carb from a big block will fit.
The HPI 4.6 is a big block but the outside diameter
of the carb body where it fits into engine block is bigger
then an S-25 carb body. Not all big block carbs will fit.
I have a 4.6 carb and it is much bigger. I've been fooling
around with carbs for the S-25 for almost two years and
it looks like a carb off anything bigger than a .26 will not fit.
Old 11-01-2006, 07:07 PM
46u
46u's Avatar
I have never had a problem to date with a composite carb but there is a reason they are going to composite as the composite does not hold heat like metal and cuts down on vapor locks.
Old 11-01-2006, 07:20 PM
DaveG55
DaveG55's Avatar
ORIGINAL: fxrs
Thank's for that.
Sorry for the miss info.
Old 11-01-2006, 08:07 PM
benzzyo5
benzzyo5's Avatar
ORIGINAL: fxrs
yeah second that i have a carb from a .28 axial aand it won't fit. the biggest u can go is a .26
Old 11-02-2006, 07:12 PM
Tudogs
I have run the Mach .28 carb on my Savage with no problems.
The manufacturer makes the difference NOT displacement.
