Re-Covering Question
ON, CANADA
Hello All,
Need a tip for removing some very tacky adhesive from an airframe i am stripping in order to re-cover it. Not too familiar with what type of covering it was, seems fairly old, and unlike anything i am used to seeing. Heating the material with a heat gun was necessary to entirely remove the old covering and the sticky adhesive was the remaining result. Nothing i have tried seems to be able to take it off effectivly. any suggestions????
Adam
Adam
RE: Re-Covering Question
Citrus-based sprays are available for removing goop too - beware though, will also remove some paint so watch where you spray it. You can get it in supermarkets here in Oz.
Cam
Cam
The adhesive is a solvent based adhesive. You said it was "old". Old stuff was all solvent based. The solvent was probably Toluene which can be cut with either the acetone or better yet (NOW PLEASE! LET'S NOT LET THIS THREAD DEGRADE INTO A DISCUSSION ON TOXICITY OF MEK.) ... MEK or Methyl Ethyl Ketone. Yes, it stinks and yes, it kills brain cells but we "Senior" modelers have all used Ambroid cement and we're still here to talk about it. Fingernail polish contains Toluene and now there is a warning on the bottle. Did it stop the women from using it?
MEK is a solvent designed for and in the same group as Toluene. It will soften the adhesive and is the best thing to remove it. That's what it was designed for. Yes, it is available nationwide and usually at that big orange sign (Home Depot) or Sherman Williams paint stores.
CA with kicker produces a poisonous fume. Are you going to stop using CA. I think not but this thread, trust me, will now dissolve into a discussion on how toxic MEK is.
When you go to the EPA web site, be sure to read the entire page on MEK. At the end it says there is no data to confirm carcinogenic properties. Meaning it will kill brain cells at the same magnitude as Crown Royal or Smirnoff but it won't make your future children look wierd with three arms or contribute to your demise with some form of soft cell cancer.
Here we go........
Here we go........
