servo selections ???
I bougt a edge 540-t arf airplane from flair, and i was wandering abougt what kind of servos i should use.
there are 2 servos for the elivator - 1 for the rudder and each one for the ailrons.
Itīs a 12 pound, 78" wingspan ,whith a 120 cu.in- 4 stroke os engine.
How stong servos should i use???
p.s. iīm trying to do it the theap way
You get what you pay for.... want to be theap? Make your own goo cleaner... use a chicken stick.... finish your plane with inexpensive paints or covering or build your own plane instead of buying an arf, but buy the best servos and radio gear in general you can. Is there a difference between name brand and x-brand? Yes and it is huge. Differences you will notice between off brands and JR or Futaba is the ability to a) center, b) holding power and c) reliability. You might be able to get by without the best of a&b, however, you only get one chance with C IMHO. The cheapest servos I ever use are HiTec(it is rare I use anything other than JR or FUTABA) though others will surely be hold opposite opinions. Good luck.
My Feedback: (16)
If you haven't already done so, run a search on your plane. I'm sure you will find lots of people with that plane. There will be plenty of information about what they are using too!
Mike
Mike
