noob. many questions
Old 01-27-2007, 12:12 AM
northern_blades
Default noob. many questions
ok.
in short, I don;t know squat.
a friend picked up a savage X little while back. not the brightest bulb, nor what I woudl guess to be the most suited to the hobby.
H ended up messing will all of the carb needles, without ryme nor reason..
I attempted to reset factory for hem (flush)
I had to back the Idle pin off, nearly 2 full turns.
now here is where the problems come in
It seems to idle well,
seems to run rich, (as I was tought it should)
but if at anny point he touches the breaks, IT KILLS IT dead, instantly.
pinching the fuel line, does not result in higher revs befor shutting down.
and it never does realy seem to warm up (it is quite cold out roughly freezing)
I was also wondering the difference between making modificatios to the "high" and "low" as opposed to setting the "throttle trim"
I can see the carb opends up 100% .. maybe even further, but when breaks are aplied, dead instantly. while running there is no break dragg. any sugestion.
make sure the sugestions come from facotry, as I suspect next time I see him, it will need to be factoried and retuned.
I have also read different articles as to break in. regardless it looks like he is running the 3-5 tanks (puttering around the parking lot at 1/2 throttle.
Old 01-27-2007, 05:04 AM
naynay12
Default RE: noob. many questions
Lol,i have the same problem.Plese help us!!
Old 01-27-2007, 12:38 PM
northern_blades
what is the difference between adgusting the idle screw, or throttle trim?
Old 01-27-2007, 04:15 PM
northern_blades
well, adjustement of the Idle screw seems to have helped.
still seems like the servo is pushing against the carb, but the screw stopps it. I do not know if this is right, but it works.
as for the trim aspect. now it makes sense also.
Old 02-02-2007, 04:04 PM
Azza10
If it cuts out then u should adjust the idle screw so it idles faster is what ive been told and it worked too...
Old 02-06-2007, 12:22 AM
20%nitro
if you havent fixed the problem yet maybe this will help. if your engine idle speed is set with your trim and the idle speed screw is adjusted too low, when you apply the brake the servo also returns the throtle to the idle position that the screw is adjusted to and if that is too low the engine dies.
i only use the trim in case i need to have the engine idle a little faster and dont have someone to hold the trigger while i adjust the carb. after the carb is adjusted i return the trim to its normal position
if
Old 02-16-2007, 02:57 PM
rushevoross
check to see if there is a 1mm opening in the carb by taking the air filter off
Old 03-15-2007, 07:30 AM
LouiHPI
myne is doing the same thing i have just took myne into the shop and has been serviced i am going to pick it up on friday and i wll ask him about it when i go in !
