TOO LEAN OR NOT TOO LEAN??
JUST a quick question i always worrie about running the engine too lean (3.3) at the moment i can see not a lot of smoke under acceleration
but if i put my hand over the exhaust the is unburnt fuel and it dosent feel as powerful as it should
there is no hesitation or lack of power
will i get hesitation b4 there is no smoke of after
JUST CONFUSED HELP?
JUST CONFUSED HELP?
VA
RE: TOO LEAN OR NOT TOO LEAN??
richen the motor up a bit my 2.5 was acting simmilar simptons it ran so dange good when i got it broke in had verry little no smoke and them she locked up from runnign to lean. is if no smoke richen up the motor till you start to seesome smoke
but i do that then it bogs down and doing the pinch test on the low speed needle is about 6 to 7 secs where as at the moment its andout 4 so i thought i was a little too rich ?
