Need Balsarite?
Balsarite
They make a formula specifically for better film adhesion. Do not use it to fill balsa sheeting before sheeting a wing thought. Use the standard formula for those projects. I found out the hard way and my sheeting didnt stick in some areas. Ughhhhh!!! It will also fill the grain, but sand smooth after applying.
Need Balsarite?
Don't use it! If you want a smooth finish for monocote do the following.
Go to home Depo and buy a product called:Bullseye Shellac sealer & finish its in the spray paint dept.
Spray on 1 med coat and let dry
Then sand with 320 till smooth
Then spray on 1 more thin mist coat let dry
Finish with 400
Your surface will look like Glass
you don't stop playing cause ya get old.... Ya get old cause ya quit playing!
Finish with 400
Need Balsarite?
Originally posted by Vince
Personally, I do not use the cr^%. If you do use it, do not put it all over your model, it will make recovering it a real pain.
Vince
Vince
SEALING FOR RESIN
You can use regular cheap hairspray to seal wood so it doesnt absorb to much resin. We use it when sheeting the wings on our pattern planes to help keep them light. After applying a heavy spray of the hairspray let it dry good and sand lightly.
