spur gear
ON, CANADA
spur gear
Have recently put a OS VG30 motor in my Savage.
Now that it is broke in can keep the lock nut on the spur gear.
Fixed by appling a second nut as a jamb nut
Just wondering if anyone else has had this problem.
Thanks Steve
Thanks Steve
ON, CANADA
RE: spur gear
forgot to mention that I went through three new nuts That is what I thought with the first one but when three more did it thought that I would ask
PS Engine works great set up is good,gears are lined up perfectly
Steve
Steve
OH
RE: spur gear
i couldn't imagine the nut backing itself off...that's weird. is your slipper pad worn out? try replacing it and scuffin up the metal slipper pad with some 600grit sandpaper...
This is gonna make me NOT sleep tonight:| which verison of the Savage is this in? single pad slipper or dual pad slipper?
