Help scaling up from plastic kit
Old 05-07-2007, 11:03 AM
harrierav8
Default Help scaling up from plastic kit
Hi All,
I want to build a 1:6 scale Harrier AV8. The problem is there are no plans available or if there is I cant find them?
I have brought a 1:24 scale airfix harrier in the hope that I can use this to draw a plan from.
can any one point me in the right direction? how would I get the fuz cross sections and wing sections from this?
Thanks in advance
Ged
Old 05-07-2007, 11:55 AM
scratchonly
Default RE: Help scaling up from plastic kit
Use fuse half to get the side view; this will give you height of formers. After drawing fuse side on paper, decide where you want formers and draw them in. cut the other side with a fine saw at the former locations. This gives you half formers. Same with flight surfaces. Scale them up to the size you want. Divide the wing span you want by the w/s of the plastic kit; use this number for all measurements. A ruler in tenths of an inch Or a metric ruler is very handy, as is an electronic caliper.
Old 05-07-2007, 05:40 PM
harrierav8
Thanks scratchonly at least I know where to start now.
if anyone else has any idea's please let me know
Thanks again
Old 05-07-2007, 06:20 PM
MinnFlyer
MinnFlyer's Avatar
Glue the two fuse halves together and run them through a band saw at strategic places to trace the fuse formers
Old 05-07-2007, 07:24 PM
iron eagel
iron eagel's Avatar
ORIGINAL: harrierav8
Hi All,
Thanks in advance
Ged
Check out this link!
http://www.nextcraft.com/plastic_to_rc01.html
Old 05-07-2007, 08:56 PM
FokkerAce
name escapes me, but one of those things with all of the little metal sliding bits, that's used to copy wood mouldings, ship hulls, etc...
? copy gauge, finger gauge, ????? ya know, one of those who-ha's
Old 05-08-2007, 12:16 AM
tailskid
My Feedback: (34)
tailskid's Avatar
Is it found at all hardware stores? If so, I know what you mean, just can't think of its name either
Old 05-08-2007, 04:46 AM
tasesq
Contour Gauge?
[link=http://www.epinions.com/hmgd-Shop_Tools-All-Craftsman_2_pc__Contour_Gauge_Set_29851]Contour Gauge[/link]
Old 05-22-2007, 12:34 AM
Jgear
A pantograph is also handy when enlarging from small drawings, the scale can be setup on the pantograph itself
