GAS with magneto + FM PCM?
i'm going to by Fuji 24cc engine with magneto ignition for 2m giles 202, which i'm building now and will become not more than 3kg without engine.
the question is: will magneto relay on reciever working? won't this cause some failiures in FM or PCM radio?
now i have HITEC ECLIPSE (FM40) bot going to by FUTABA 7C(PCM)
http://www2.towerhobbies.com/cgi-bi...p?&I=LXNRH4&P=0
AB, CANADA
RE: GAS with magneto + FM PCM?
Hey Bako! Long Time, no hear....where have you been hiding? There should be no reason why a magneto ignition should not work with PPM; the key is getting it set up right so as to eliminate any source of interference. If by magneto relay, you mean some sort of kill switch, I think that there should be no reaseon that will not work as well; especially the optical ones, so there is no physical connection between receiver and engine.
There are those who will say "never use Hitec with petrol engines", but I will leave that from them to say. There are also those that will ask why you don't get "some other engine brand". I will leave it to them as well
heya all. i'm now teching in Kharjkov aviation institute in Ukraine, so rc hobbie isn/t so active now. after 2 weeks i'll have to cmplete the Diplom work on theme sport plene, which i'll engineared in 4 years
thanks for answers, i'm now selling KATANA:
wingspam 1,47
weight 2.7kg
engine magnum 91RFS
400cc fuel tank,
perry pump,
fuel filter, battery monitor. start case, hand fuel pump, 4 glow plugs and all accsories
all this 800$
after selling going to go on petrol. new 2m giles 202 is beeng builded, all photos an comment of process will be soon
wingspam 1,47
weight 2.7kg
engine magnum 91RFS
400cc fuel tank,
perry pump,
all this 800$
DC
All this talk about PCM, PPM, etc...
I wonder how we ever flew magneto gassers 40 YEARS ago with AM and no fancy radios or shielding ? Q35s, G38s, Q52s etc...Betcha ED Cregger was there
ORIGINAL: bako1
here will be good choise 45-50cc gas engine
