Picco .26 Engine Mount
Old 07-15-2007, 05:31 PM
wmdiotte
Default Picco .26 Engine Mount
I have a ofna picco .26 outlaw i want to put on a revo. I was wondering if anyone has this setup and what engine mount i should use?
Old 07-15-2007, 05:40 PM
Danju
Danju's Avatar
Default RE: Picco .26 Engine Mount
use the revo mount for the picco 26 max:
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXKHF4&P=M]mount[/link]
Old 07-15-2007, 07:34 PM
x5t1j
ORIGINAL: Danju
Can't you read! He said he had an Outlaw not a max! That mount will do anything for him. The Outlaw is a big block case and the max is a mid block.
You can use the Traxxas big block kit (wich also comes with the FOC) New Era Models makes a nice one and so does Qoncepts.
Old 07-15-2007, 08:03 PM
wmdiotte
yeah i tried the traxxas big block kit, just bought it today and tried putting it on but it didnt seem to fit right. But i didnt fool around with it too much. The revo already came with the outlaw installed but the way the throttle bell crank was positioned with the supplied mount the carb wouldnt slide in and out smooth....sometimes even getting stuck open while test running it. Just image me running after it lol. Anyway i tried the traxxas kit but dont think it had the right bracket for the throttle bell crank. Any help?
Old 07-15-2007, 08:44 PM
wmdiotte
ORIGINAL: x5t1j
Well after i read your earlier post i looked up the New Era mount and thats whats on my revo now. The orange arrow shows an allen head screw that goes in that piece that the green arrow is pointing to. Well that piece the green arrow is pointing to is stripped making the throttle all sloppy and making the carb stick open. Bad design on New Eras behalf if you ask me. Its made of like that cheap metal material and i guess the person that owned the revo before me over tightened it and stripped it. I just bought that traxxas big block kit thinking that what i had on their now wasn't the right mount.
Old 07-16-2007, 12:46 AM
LSTVega28
LSTVega28's Avatar
ORIGINAL: Danju
Outlaw=BB
Max= MB
Old 07-16-2007, 12:35 PM
Danju
Danju's Avatar
ORIGINAL: x5t1j
ORIGINAL: Danju
Can't you read! He said he had an Outlaw not a max! That mount will do nothing for him. The Outlaw is a big block case and the max is a mid block.
okay okay...just calm down. i thought they were the same engines....i made a mistake and you guys fixed it for me, thanks.
Old 07-16-2007, 04:21 PM
wmdiotte
give the man a break lol. But i would of probably bought that if no one said anything. THANKS!
Old 07-16-2007, 08:49 PM
x5t1j
Ok let me see if I have this right. The housing that holds the throttle linkage is stripped and the bolt wont stay tight correct? If so then I would try two things. If it still has some threads left try using some threadlock to prevent it from coming loose. If that dosen't work then I would get a longer bolt that would reach all the way through and put a nylon lock nut and a flat washer on the bottom. Hope that helps you let us know how you made out.
Old 07-16-2007, 08:53 PM
wmdiotte
okay will do thanks
