11.1v battery with 480 brushed motor?
I have a Cessna 182 4Ch which i bought from Parkflyers http://www.parkflyers.com/html/cessna_182.html
It has a 480 size brushed motor that works with the stock 8.4v ni-mh battery. I would like to know if somebody knows the voltage range the motor and the speed control can handel. I want to put in a 11.1 v Li Po battery since 7.4v reduces power. Will 11.4v burn the motor? If yes, If I fly below 75% throttle with 11.1 v, will the plane be ok?
I will really appreciate if you reply.
Jag
Jag
RE: 11.1v battery with 480 brushed motor?
Yes the 11.1 volt will burn up the motor. If you reduce the throttle, all you are doing is reducing the amp draw, not the actual battery voltage. You are still supplying the motor with 11.1 volts from the battery. The 2 cell pack would be the way to go. When fully charged, a LiPo hits 4.2 volts per cell. So a 2 cell LiPo will hit 8.4 volts when fully charged. Plus it is much lighter than the NiMh you are running and you will see a performance increase just do to the lower overall flying weight.
The question I would ask......Why not just convert to brushless? If you are going to spend the money on a LiPo anyway, just get a brushless motor and ESC as well. That way you would get the most out of the $$'s you would be spending.
Hi Jag -
There is considerable information on this topic here:
[link=http://www.rcgroups.com/forums/showthread.php?t=201680]Can motors on 3s LIPO [/link]
- Jeff
- Jeff
ORIGINAL: 4*60
I've been using 3 cell Lipo on speed 400 brushed and have quite a few flights. Some day I will burn them up and install brushless motors on them.
I know that some manuf. sell the SPEED 400, 480, 500 & 600 in a regular 7.2 volt version, and a 12volt version. The 12 volt can motors would obviously be fine on a 3 cell LiPo. Most of the RTF motors, like this Parkflyers one, are only rated at 7.2volts.
Go down a inch in pitch and a inch in diameter on he prop and it will work OK I have found. I use 3s all the time on 7.2v 400s both DD and geared. The 6v motors have to be coddled a little though with the throttle stick and still suffer in lifespan. If its the 12v 480 you will have no problems. Lots of sailplane guys usued them will 10 cell nickel packs and had no problems so 3s lipos should be a breeze!!!
Good Luck
Bob
Good Luck
Bob
NC
I don't want to hijack the thread, but if I might ask a question along these same lines?
I have a plane that came stock with a brushed 480 motor and an eight cell, 9.6 volt NiMH battery.
Would the general consensus be that this is a 7.2 volt or 12 volt motor?
Or is there really no way to tell?
ORIGINAL: Sir Raleigh
jag5100 you will probably find the cessna flies quite well on the 2s LiPo. While the voltage is reduced, the number of amps a LiPo can produce is so much higher than NiMH/NiCd it usually more than compensates. As you probably know power = volts x amps so the amps you can produce are just as important as voltage.
Also, a 3s will work fine on just 400/480 can motors, but it will accelerate their deteroriation. However, it needs to be understood that electric brushed motors wear out - that's normal. Brushless motors tend to wear out very very slowly because there is no contact, but a brushed motor has wear on the brushes.
With a 480 motor costs $15AUD here you will get 30 flights or so on 3s no probs. I'm guessing in the states that motor probably costs around $5. Not big bucks.
Cheers,
Oz.
Cheers,
Oz.
Thanks. I looked in detailed about putting in a brushless motor. Then I will have to change the motor mount and ESC. Thats not a big problem. I will actually have to rebalance the plane since brushless motors weight different than my brushed motor. I know I will crash it if i rebalance it, lol.
I think it came with a 8x6 prop. soarhead-RCU wrote that if i go down an inch on pitch and prop size, probably 7x5 prop. Will it work good?
I wrote to the Parkflyer manufacturer. This is what they said, "Dont use the 3 cell battery ! it will fry motor in less than 1 minute". However I did not ask them about going down in the prop size. Do you guys think 7x5 prop will make the plane alive with 3 cell li-po? Worth a shot?
Hi Jag - just from personal experience, my best flying mate has flown a 3s in his PZ Supercub - he gets about 30 flights from a 480 motor before it needs to be replaced.
Always hard with conflicting opinions eh
Cheers,
Oz.
Cheers,
Oz.
NC
ORIGINAL: fliprob17
I would venture a guess that it is the 7.2volt, seems to be the RTF standard. The only way to find out for sure is to contact the manuf. of the plane it came with and ask them. They generally are not labeled.
It was just a question asked out of idle curiosity, so I'm not going to worry about it. I already have a brushless outrunner and ESC in the wings (pun intended) waiting to be installed when the brushed motor wears out.
Thanks again.
ORIGINAL: jag5100
ORIGINAL: ozrcboy
Batteries don't "produce amps." The current (amps) consumed by a power system is determined mainly by the motor and the prop, not the battery. The power system will attempt to draw whatever current it needs from the battery, regardless of the battery chemistry. You can make any power system draw more amps simply by increasing the size of the prop!
Lipos are popular mostly because they are so much lighter than the NiMH batteries they replace. You will often see a performance increase due to weight savings alone. But the power system won't necessarily draw more amps from a Lipo battery than it does from an NiMH.
- Jeff
Thanks fliprob17,
......I already have a brushless outrunner and ESC in the wings (pun intended) waiting to be installed .....
Thanks again.
Thanks fliprob17,
Thanks again.
I have found that if you're using the speed 400 motor as a direc drive i.e. in a flying wing or a pusher jet... you will burn it up in just a few flights with a 3cell Lipo. If however you're using it with a gear box with a 5 or 6:1 ratio, they can last quite a while as long as you're not over propped & are easy on the WOT action. Good luck.
Rick
Rick
ORIGINAL: jdetray
Oz -
- Jeff
ORIGINAL: ozrcboy
- Jeff
I agree. However i also tried a 9.6v Ni-mh 650mah battery on Cessna. The plane only worked for 1 min on that battery. the battery was producing a lot of volts. Do you think the battery is bad or it is 650mah thats why it won't last long?
ORIGINAL: jdetray
Oz -
- Jeff
Oz -
- Jeff
The planes I've seen use 2s into instead of a 7/8 cell NiMH/NiCd the difference in performance is not explained by weight alone - weight changes would affect acceleration, stall speed and climb rate, but it has no significant affect on top speed in level flight (which is all about how much thrust the engine can produce relative to how much drag the airframe induces at a certain speed). Further, in a static thrust test it is obvious just by holding the plane how much more thrust it has with 2s rather than 7/8 cell - well, at least that's what I think.
Cheers,
Oz.
Basically, you're sucking all of the power out of the battery when you overload it like that.
- Jeff
