OMP - Ohio Model Products Support Forum Discuss products and get support from OMP. This forum is operated by the owners of OMP and your support questions or complaints will be handled as OMP deems appropriate.
Katana ARF
Old 12-18-2004, 12:23 AM
srg123cohen
My Feedback: (13)
srg123cohen's Avatar
Default Katana ARF
Does anyone else's have a little notch beetween the lower two ca hinges on the rudder. I was looking at this and wasnt sure if the rudder is damaged or not.
Old 12-18-2004, 12:30 AM
STLPilot
My Feedback: (21)
Default RE: Katana ARF
Yes, you need to cut the monokote off ... when you attach it you'll notice that you need to remove it.
Also helps to get a razor and bevel that groove to give the rudder max deflection.
Make sure you test full travel movement on ele and rudder before you glue it!
Old 08-29-2007, 08:41 AM
Bxtreme aviator
Bxtreme aviator's Avatar
hi guys
ja i had da same problem but made myself a new rudder works wel till now what engine are you using im using a OS46 with tune pipe and seems to be working fine.
cheers
jp
Old 08-29-2007, 12:27 PM
AFSalmon
AFSalmon's Avatar
That notch I believe is to clear the elevator joiner rod when the elevators deflect up or down.
