What glue for EPS foam?
Old 11-04-2007, 05:53 PM
unlimited racer
My Feedback: (53)
Default What glue for EPS foam?
I was wondering if anyone can tell me what glue I can use to take 2 pieces of EPS foam measuring 2" thick to create a piece that is 4". I cannot locate anything here locally that is already 4" so I can cut it with a foam cutter. Thanks for anyhelp!
Old 11-04-2007, 07:15 PM
Jon.
Default RE: What glue for EPS foam?
You should be able to use epoxy.
Old 11-05-2007, 03:39 AM
w5kfg
w5kfg's Avatar
ORIGINAL: unlimited racer
If you try to cut the foam with a hot wire cutter it wil not cut through the foam at an epoxied glue line, I have had success hot wiring foam that has been glued with 3m super 77. I hope this helps
Bill
Old 11-05-2007, 06:24 AM
bps
bps's Avatar
Try using a polyurethane foam glue such as Gorrila Glue.
Old 11-05-2007, 07:02 PM
unlimited racer
My Feedback: (53)
Thanks for the replies. I was thinking Super 77 but just was not to sure. Thanks again.
