RC Rock Crawlers The official rock crawling forum right here on RCU. Rock Crawler Trucks Rule!
Wheely King Slipper Question
Old 11-05-2007, 06:37 PM
Maggster
Default Wheely King Slipper Question
Hey guys, I just got a used WK. It came without the stock motor, but had a brand new Venom Fireball 19 turn motor with it. I broke it in, installed it with a 21T pinion, and tried to run it. I get a LOT of clicking out of the tranny. Anything over about half throttle clicks.
I assume this is the built in slipper, does that sound right? What does that mean? Does it need adjusted, replaced, or ????
Thanks.
Old 11-05-2007, 07:56 PM
The Real Dogman
The Real Dogman's Avatar
Default RE: Wheely King Slipper Question
sounds like the clicker clutch is a bit worn, there is no adjustment. You will have to either lock it or replace it. Not sure where to get the parts, since I have eliminated it with my new custom clocked case for rock crawlers
Sorry for post whoring just couldn't help myself, I am so pleased how it turned out, might manufacture them...
ID:	797812   Click image for larger version
ID:	797813   Click image for larger version
ID:	797814   Click image for larger version
ID:	797815   Click image for larger version
ID:	797816   Click image for larger version
Old 11-05-2007, 08:17 PM
Maggster
Thanks Dogman. I was just searching on another RC Crawling borad and found a tip to check the diff by holding the rear tires and giving it throttle. The driveshaft spun while I was holding the tires. That must mean the R&P is shot, right? Is the best solution a new set of stock R&P gears?
Thanks. And the new case looks great!
Old 11-08-2007, 08:46 PM
Maggster
Got her fixed! New diff ring gear. Took it apart and put silicone ear plugs in while I had it out. What a difference! So far, I am really pleased with the WK.
