GWS warbirds- to buy or not to buy
hi,
im looking for my first warbird! ive read quite a few posts RE the GWS planes and people seem to like them fine, more so after going brushless/LiPo...
anyway, they are REALY affordable, and i have my own radio gear and dont mind putting a few more bucks into it. i have 5 -1100mah NimH batts already, i assume they will fit, and ill eventualy be getting lipos no doubt anyway..
so anyone have any opinions on going with GWS? for the price, is it worth it?
oh ya, and have any of you added any custom landing gear? the stock gear looks brutal!
RE: GWS warbirds- to buy or not to buy
I bought three used GWS warbirds from a fellow at my field: Corsair; Mustang; Zero. The guy had modified the Corsair and Mustang to have retracts. I've flown both the Mustang and Corsair and they fly nicely, but are a real bear to land well. I bent the gear on the Mustang after two flights and have not replaced it yet. On the Corsair, I tore out the gear on the first landing. I bought new retracts from HobbyLobby and so far have damaged the plane on four landings. I just can't get the plane to land softly enough. The planes (both Mustang and Corsair) are VERY touchy to the elevator control and must be landed with a decent amount of speed, otherwise they tip stall. They turn very nicely with the aileorns, but you must fight them to do rolls. My Rare Bear, from ThunderTiger, had similar characteristics. On the plus side, they are absolutely breathtaking when they are flying, and the retracts are real cool looking.
OH
For the price Parkzones Spitfire is hard to beat. The Spitfire seems to be the most forgiving of the war birds. The Mustang and corsair are probably the least forgiving. Depending on your skill level and experience. My first warbird was the Spitfire and I love it. I also fly Parkzones P-51D and great planes Corsair. I love the Mustang though I had to send it back 3 times before I got a Rx that worked properly. This winter it's going on my Spektrum DX6. The Great planes Corsair is ok at best. It lacks power badly. This winter it definetly going brushless. Stock it does not have enough power to even power through a loop much less a roll. The bright side is the motor and gear combo sound fantastic. Best of luck with what ever you decide.
NY
Hello, I fly the GWS ME 109, P-51, Zero, P-38, Spitfire and Corsair. Out of all of them I would say the Corsair is the most stable. I do fly them all brushless with Lipos though. When you are building them always measure if your battery will fit before you glue the fuselage halves together so that you can enlarge the space if needed. When doing the maiden keep the control surface very low ( 30-50%) to make them less twitchy until you get the feel for them. I also do not use the landing gear on any of them and re-enforce the belly with clear tape or fiberglass
