View Poll Results: A poll
Voters: 29. You may not vote on this poll
stronger / better: e-maxx or e-savage
RE: stronger / better: e-maxx or e-savage
ORIGINAL: PedeBeater
The only setback of the e-savage is the drive shafts. From what I have heard they will not hold up to anything over stock.
Koolaid, when you want to upgrade motors, I would recommend the S-600s. I went brushless before I ran them in my E-Savage, but in my E-Maxx they gave a great performance increase. Even when one motor got disconnected, the single motor had more torque than both stock motors. Here's an excellent chart of brushed motors: http://www.e-savage.com/forums/showthread.php?t=8
First of all, I figured out break-in question.
TheEmaxxKid, that looks like a good option. Do you know if it's safe to go in reverse with the s-600's(or if they even will), given that they're plane motors and aren't supposed to go in reverse, the scoop on that anyways? Thanks.
ORIGINAL: 500 lb. koolaid man
ORIGINAL: calvino
I have heard you can go in reverse for short pierods of time with them, even though it isn't such a great idea for them[&o]
ORIGINAL: AutoXMan
No, you can go in reverse with no problems. I am unsure if the motors in the savage are mounted in opposite directions, if so you would need to get one s 600 r i believe. They have advanced timing and this is why. But in short I do not see why they would not be able to go in reverse, they will just be slower (due to advanced timing).
ORIGINAL: calvino
