Big problem need help
MI
I have a Duratrax Axis 1/8th scale buggy. I put a Power Racing .27 motor in it. Now in the middle of running forward it will stop and go in reverse. Its a single speed trans with forward only. So how and why is this happing. Thanks in advance.
RE: Big problem need help
Sounds as if the engine starts running backwards. Will it stop and go back forwards? If it was me , I'd try a colder plug and see if that helped. I'm stumped though so maybe someone with a little more knowledge will jump in here and be of more help.
CT
sounds like it backfired and then started to rotate in reverse, i would do what grits said and maybe add one of the smallest shims to the head to lower compression.
