foam packing
foam packing
Has anyone used that spray-in insulation foam to insulate the fuel tank from vibration? I have a cavity around the front half of my tank and the tank barely fits in the braces so I'd have to cut it larger to fit any foam around it.
i have that infamous MDS .40 that likes to deadstick, been told that it's probably from foaming in the tank.
Just thought that the foam is pretty light and I can get it into a tight spot. Any inherent problems I should know about?
foam packing
Actually fitting a tank so tightly and locking it in place place can cause foaming as well. The form packing needs to allow for shock absorbtion and not locked down completely.
Never had any luck with either MDS .40 or .48 Tried everything from to get them to run. Finally move to OS.
Life is good!!
Life is good!!
NJ
Aerosol Foam
I used that type of foam to insulate the bottom of my boat and take up space to keep water out. It's pretty hard when it cures to it will transfer vibration very well... It does expand a lot too so be careful...
Ed
Ed
MDS
the reason why your MDS engine is playing up is because there SH^TE engines!!, the 48 is the worst of the lot!, its just a bored out 30, and the head twists as the metal heats up!. The mixture changes and the engine cuts. The other motors are bad because the carbs arn't any good. they have brought out the Mk2 carbs, but they still arn't any better!
3 thinks M.D.S stands for -
More-Dead-Sticks
Metal-Door-stop
Mostly-Duff_Sh^te
cheers
Andrew, from the rainy UK
More-Dead-Sticks
Metal-Door-stop
Mostly-Duff_Sh^te
cheers
