2.5 flooding
Old 05-18-2008, 06:46 PM
niteblaster
Default 2.5 flooding
I have finally gotten my trx 2.5 to beable to run through a full tank without overheating 2 times not. Unfortunately it takes till almost 1/2 tank before I get it adjusted where I have great pwer and it doesn't bog or stall. Both times I thought I had it tuned perfect I would try to start it the next day and it would flood and not turn over. After I get it started it is so rich that it spits fuel and stalls when I give it any throttle. I have to lean it out on the HSN when it is 1st started then after a few minutes richen it back up. Does this sound like typical worn piston and sleeve symptoms? I bought it used with a suposed new piston and sleeve and I did the traxxas break in and I have about 1-11/2 quarts through it.
Old 05-18-2008, 06:53 PM
racemaxx24
Default RE: 2.5 flooding
Sounds like u need to ajust your LSN and idle screw
Old 05-18-2008, 07:00 PM
niteblaster
Thanks do you think I need to lean the LSN? and raise the idle? Or lean both? All help would be appreciated!
Old 05-18-2008, 07:09 PM
racemaxx24
U need to lean the HSN, LSN, then the idle screw in that order.
Old 05-18-2008, 07:48 PM
matts6887
matts6887's Avatar
make sure when u adjust the idle; that u adjust it so that there is about a 1.25mm opening when u look down into the carb barrel when its at the idle position. Or about the thickness of a credit card.
Old 05-19-2008, 05:22 AM
RCCanuck
and after every adjustment make a ferw high speed passes to clear out the carb and to see what the adjustment did to the performance.....thats the best way to learn tuning.
