Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Car Radio Equipment
A quick and possibly stupid question
RC Car Radio Equipment Discuss specific topics related to RC car radios. For general or non rc car specific radio topics please see our regular radio discussion forum.
Old 06-14-2008, 05:44 AM
FuelLeak
Default A quick and possibly stupid question
Greetings all. Just a quick one that I cant seem to get an answer to at my hobby shop. Feeding a reciever antenna into a new antenna tube is a pain. My technique is to twirl the antenna tube as the wire feeds into it (painfully slow). Am I doing any damage to the metal wire inside of the antenna wire casing? It is my thought that twisting the antenna wire may be doing some harm, although all of my cars' radios work fine (so far).
Old 06-14-2008, 10:50 AM
Osirisf16
Osirisf16's Avatar
Default RE: A quick and possibly stupid question
Not at all, it's fine. BUT there are some other ways to feed an antenna through a tube. The first is to put some oil, feed a little, take it out, put some oil, feed it and slowly slowly it will be veryu easy to put the antenna through the tube. The other way which is ULTRA easy, is to put the antenna in a flour (cooking material) and try to feed it throught he tube. You will be surprised how easy it is, i recommend it.
Old 06-14-2008, 09:14 PM
systemlord
The only way I've been able to get the antenna wire through the straw is spraying Windex inside the straw then feeding it through. After run oil will work also, but I wouldn't use motor oil though. See Windex has drying agents in it to help it dry. It would be pretty hard to hurt the antenna wire feeding it through a straw, you could never be able to aply enough pressure.
Old 06-15-2008, 02:40 PM
dacaur
dacaur's Avatar
ive tried flour and oil, it kinda works and gets the job done, but isn't always easy... try getting a new antenna tube, the ones you get separately at your LHS for like $1 are normaly easier.. another method is to get some thread, thread it through, wrap it around the antenna a bunch of times, and pull it through.
<edited for spelling>
Old 06-15-2008, 04:16 PM
systemlord
I have found the Traxxas brand antenna tube to be the least bendable (lot more stiff) antenna tube out there.
Old 06-15-2008, 11:59 PM
Osirisf16
Osirisf16's Avatar
Flour is the best solution for me. None problems.And is kinda cheap, don't you think? instead of after run oil. If you are too husty, then yes, you might don't get the job done but who is hurry? I mean, this is a hobby of patience and a whole of time.
Old 06-16-2008, 07:46 PM
Anomie
Anomie's Avatar
I've used flour also, and it works pretty well. I tried speedo cable lube (graphite) one time and it worked even better, albeit a tad expensive.
The last time I ran the antenna in an extended pipe I had to poke a stiffer piece of copper wire through, soldered the antenna to it tip-to-tip, and then pulled it through. It was a bit of work, but did the job.
Old 06-19-2008, 09:35 AM
FuelLeak
Thank you to all who responded to my question. I really appreciate the advice, and I will definately be utilizing one of your techniques in the near future. A giant thanks again to all of you!
