lockers..
How bad will it be to run on solid surfaces with a locked rear end ??? How hard will it be to sreer with a locked front end ?? and last what can I do for some limited slip on the front >>>
PA
When you lock the differentials it widens your turning radius by quite a bit, but considering that these are rock crawlers it really doesn't make a big difference.
What truck are you referring to? Sometimes you can put thick grease in the front if you want it to act like a limited slip. It really depends on how your diffs are made.
