Elevon travel issue...
IL
Hi,
I have a RICCS RTF Mirage 2000. While putting it together I noticed upward Elevon travel differs on each wing (left up elevon travel is greater than right up elevon travel). Can you please tell me how to correct this issue and balance out the travel. Note: elevons are in balance at neutral stick and both horn/clevis adjustments are identical.
Ken
Ken
My Feedback: (21)
RE: Elevon travel issue...
What are you using for a radio?
Make sure the ATV is set equal on both the elevator and rudder channel. That's about the only thing I can think of that may be causing the issue.
Oh, are the servos identical?
