GP Pitts Airfoil
GP Pitts Airfoil
Just started on mine and noticed that the bottom wing is symmetrical and the top is symmetric. All reports indicate it's a great flier. The only full size ones around here both wings are symmetric. Here's hoping, Skip
GP Pitts Airfoil
I'm working on it now and can hardly wait. I picked up a BME 50 with the Pitts muffler and it is going to be an easy installation. I'm now flying a Lanier CAP with a G62 at 19.5 lbs. Flies great, lands like a brick (approach approx, Mach I). With all the frontal area of the Pitts I will be accustomed to carrying power all the way to the ground. Since I've heard nothing but good things about the flying characteristics of the Pitts, I quit worring about the airfoil configuration, although it does seem wierd to me. The CAP goes to the belly in knife edge, the Pitts will probably pull to the canopy.
My Feedback: (46)
GP Pitts Airfoil
Pitts need a lot of roll coupling on knife edge, it pitches toward the belly, I have been flying mine with g-62 for 1 1/2 years, great flyer but a brick on landing, keep power on until close to ground. If you chop the throttle too soon it will stop & drop like a brick.
Gil
Gil
My Feedback: (46)
GP Pitts Airfoil
I used four servos, two left together with y-connector & two right the same, I put two ernst charge jacks right behind the cabane struts & split the ailerons between channel 1 & 6 for flapperons & spoilerons. I use a futaba 6xas radio. It works great, I probably went a little overkill on servo's 4- 110 oz analogs on ailerons, 2 of the same on rudder with pull pull set up & two of the same on elevators. Plenty of control authority. I used a g-62 for power with a j&a pitts muffler with smoke, tme smoke pump & 24oz smoke tank right on cg. Any info I can help you with I'll be more than happy to do.
Gil
Gil
