Twin Cat Video
Twin Cat Video
Here is a link to video that was taken this past Sunday of my Twin Cat. I finally conquered the counter rotating engine that I have been working on for a month or so and this shows how it paid off. Now I can turn left under full power!!
Don't use this link as it does not work. Go down 4 posts to Ron's and clik on his link. It works. Thanks
[link]http://www.youtube.com/watch?V=H4TyaVOxQvQ[/link]
Rick
Rick
RE: Twin Cat Video
Sorry, I know the video does not work. Someone just told me. I don't know how to fix it.
I sent the same link to an e-mail address and it worked fine? I don't get it. Maybe someone can tell me how to fix it?
Rick
Rick
RE: Twin Cat Video
I guess that is part of the problem. I don't have a You Tube screen name. Wally took the video and sent the link to my e-mail address. I forwarded that e-mail to a frined and the link worked. So I put it here and it does not work??????????
Rick
Rick
RE: Twin Cat Video
OK, this is probably it then: http://www.youtube.com/watch?v=H4TyaV0xQvQ
Wonder how I found it? I had one of Wally's other videos saved in my favorites!
RE: Twin Cat Video
The only difference that I see between what I typed and what you have is a lower case V after the question mark. Would that make the difference?
ON, CANADA
RE: Twin Cat Video
great vidio what type of hull is that looks awsome how did you get the engine to run clockwise did you change the timming or was the engine turned aroung great rigging verry clean
ON, CANADA
RE: Twin Cat Video
NY
RE: Twin Cat Video
Rick, You did a great job on that project and it sounds soooooo sweeeeeeeat Getting my parts together to start a CCW Zen project, may have to pick your brain
John
John
RE: Twin Cat Video
Showtime- The props are 7016-3 SS from Voodoo. No changes to the transom except rudder linkage is now beefier.
Wally- Thanks again. I am really glad that I stuk with it and didn't give up. I knew it was do-able! Just had to find a way!
rcguy- The hull is an Expresscraft 60" Cougar Cat. The engine was a bit of a project. A lot of trial and error. It is mounted in the normal position. The crankshaft is turning in the opposite direction from stock. I did this with a different pull starter. I turned the coil around, modified the flywheel, and turned it around, and retimed it.
Phil- There are some pics already on here somewhere. I will try to find them and repost. I will also take some new ones first chance I get.
John- Thank you. A friend is starting a CCW Zenoah project also. Maybe I will have more info for you by then.
Rick
Rick
RE: Twin Cat Video
Phil,
There are five pictures here in the photo gallery. They are about eight pages back. They were posted 9/13/08 so you should be able to find them by the date. I don't know how to move them from the gallery to the forum? Everything still looks the same as it did then. The difference in the engine is only that the coil is mounted backwards.
Rick
Rick
