Determining gas engine vs glow engine size
My Feedback: (10)
IN
Most of the standard models that you see out there are sized according to the glow engine requirement for that particular model, ie 4*60 or 4*120. My questions is this. What exactly determines the engine size? Is it wingspan, weight, or both? I am assuming the glow engine size units cu inches? Gas engines seem to be sized differently such as a Zenoah 26. How would I determine what the equivalent gas engine size that could be used on a plane, lets says its designated as a 90-110 (glow) size?
RE: Determining gas engine vs glow engine size
I choise engine depend on the weight .not the size. if I can balance the CG. I will put the biggest engine I can find and fly it .even oversize . like put 40CC gas engine on the plane that require 26CC for fly. over power are not bad because you can control the output youself .but less power not the good things to me
Tomy
Tomy
